Cookies don't work
Postby Rhekatou » 2010.01.13 (00:45)
With retronet as the main theme. I don't know why, I just know that now my cookies don't work. And suddenly retronet is the default.
Fixes?
Postby otters » 2010.01.13 (01:52)
Someone should remove the forums.droni.es alias, no?
Postby Rhekatou » 2010.01.13 (02:10)
incluye wrote:Someone should remove the forums.droni.es alias, no?
No, I'm on forum.droni.es.
Not forums.
Postby Donfuy » 2010.01.13 (02:12)
Did it work fine for you before? Cause it's working perfectly fine for me, and for everybody else.
The default was changed to Retronet, that's not a problem.
Postby Spawn of Yanni » 2010.01.13 (08:16)
retronet was meant to have been the default for a few weeks now, but for some reason (even though it was marked as default in the ACP) it never actually changed. I tinkered around a little bit with it last night but I can't think of how it would have affected cookies. Is this happening with anyone else?
Postby Chase » 2010.01.13 (10:19)
It doesn't keep you logged in if you just use quick login at the top. You have to click "Login" next to the boxes and check the box.
Postby a happy song » 2010.01.13 (15:09)
Whenever I open the forum after an absence, I've not only been logged out, but I've been forced back into using Retronet.
I don't like that.
Postby Spawn of Yanni » 2010.01.13 (15:15)
The new default skin is retronet, and there is a thread about this exact problem. I don't understand why only a select few (specifically, just you two so far) seem to have this problem.
Postby a happy song » 2010.01.13 (18:47)
Tried to merge them, wouldn't let me. Seems things are bugging out?
I'll lock it.
Postby a happy song » 2010.01.13 (18:48)
Same issue. Keeps reverting me to the Retronet skin and logging me out.
As soon as I log back in and move to another from, it reinstates my desired skin.
Postby  yahoozy » 2010.01.13 (21:29)
Went ahead and merged them for you, Bracky-poo.
Postby Rhekatou » 2010.01.13 (23:11)
Chase wrote:It doesn't keep you logged in if you just use quick login at the top. You have to click "Login" next to the boxes and check the box.
Check. Did that.
Postby Chase » 2010.01.13 (23:52)
Check. Did that.
Well it's just you, because they do work, it's just your PC doesn't like them.
Postby Rhekatou » 2010.01.14 (00:17)
Chase wrote:
Check. Did that.
There's another (albeit minor) annoyance.
The Quick Login has to have each field erased by a mouse drag.
But that's nothing major.
Postby SlappyMcGee » 2010.01.14 (05:04)
I have had this issue, so it is officially a problem.
I'm not sure how I fixed it, but it is veritably annoying when it happens.
Postby squibbles » 2010.01.14 (05:37)
Yeah, I got it too. D:
Postby Spawn of Yanni » 2010.01.14 (20:55)
I hate to sound patronising or something (and it looks like rhekatou already checked this) but just to cover all bases, you guys are sure you didn't just use the quick login, right? You need to go to the main login page and check the "remember me" box.
Postby a happy song » 2010.01.14 (21:06)
Spawn of Yanni wrote:I hate to sound patronising or something (and it looks like rhekatou already checked this) but just to cover all bases, you guys are sure you didn't just use the quick login, right? You need to go to the main login page and check the "remember me" box.
I figured this out a few hours ago.
Dumb dumb dumb.
-_-
Postby Rhekatou » 2010.01.15 (01:18)
Dumb dumb dumb.
-_-
I figured it out on the second try.
And it didn't work.
It also logs me out when I click a link (Ie: Yanni just sent me a link to the image worm, but clicking the link logs me out).
Postby SlappyMcGee » 2010.01.15 (06:07)
I had the issue because I clicked a link that was mailed to me for a PM, and those still link to easterviking. Which is an issue that needs to be fixed.
Postby otters~1 » 2010.01.15 (14:50)
SlappyMcGee wrote:I had the issue because I clicked a link that was mailed to me for a PM, and those still link to easterviking. Which is an issue that needs to be fixed.
Even if you open it in a new window?
Postby SlappyMcGee » 2010.01.15 (14:51)
What? The emails that are sent out for PM's link to EasterViking. That is just true. :/
Users browsing this forum: Baidu [Spider] and 16 guests
