Ninjarobotyeti.com
Postby EdoI » 2009.12.24 (14:24)
  1. NUMA hover profile in the forum isn't working well.
  2. The main site is still titled "TheRealN".
  3. Typecocks isn't working well, sends data to therealn.com.
  4. None of the links at the main site is working.
  5. Filmroll.droni.es redirects to the therealn.com domain.
  6. Sotx has "Back to The Real N" button.
Postby SlappyMcGee » 2009.12.24 (15:57)
Yeah, we know.
Postby otters~1 » 2009.12.24 (16:33)
I asked on IRC and Lenny or someone said, I think, that LV had to change all those links. Which is true about everything around here.
Intel 80486
Postby epigone » 2009.12.25 (04:03)
While we're listing problems, the new site doesn't keep me logged in. I've already voiced this in the moderator discussion forum, but this way we can see if anyone else is having this problem.
The Best of Epigone
Postby SlappyMcGee » 2009.12.25 (05:14)
Have you tried either of the suggestions I've given in that thread?
Postby Lenny » 2009.12.25 (09:17)
There's a lot to be changed, yes. But if the links are changed here then they won't work on EasterViking, I believe. So we'll probably wait until after the new year - it'll just be a matter of time. But the essential things are all working.
Postby Donfuy » 2009.12.25 (19:41)
epigone wrote:While we're listing problems, the new site doesn't keep me logged in. I've already voiced this in the moderator discussion forum, but this way we can see if anyone else is having this problem.
Actually, ninjarobotyeti is the first domain that actually logs me in automatically.
It never worked for me, not even on the old old forums.
Postby Spawn of Yanni » 2009.12.25 (20:00)
It's gotta be some issue at your end. Try refreshing various internetthings is all I can suggest.
Postby EdoI » 2009.12.25 (22:36)
Lenny wrote:There's a lot to be changed, yes. But if the links are changed here then they won't work on EasterViking, I believe. So we'll probably wait until after the new year - it'll just be a matter of time. But the essential things are all working.
EasterViking is just a backup host for everything, it won't be a big deal if it stops working now that we have this primary domain.
Postby otters » 2009.12.26 (03:50)
Can't someone do a search-and-replace in the database for URLs that start with http://forum.easterviking.com and http://forum.therealn.com and replace them with http://forum.droni.es ?
Postby SlappyMcGee » 2009.12.26 (03:57)
Wight wrote:Can't someone do a search-and-replace in the database for URLs that start with http://forum.easterviking.com and http://forum.therealn.com and replace them with http://forum.droni.es ?
I assume so.
Postby EdoI » 2009.12.26 (16:10)
Give some TRN link.
Postby Lenny » 2009.12.26 (22:49)
Not necessarily. If you make it too specific, it might not catch everything; yet if it is not specific enough (like just looking for "TheRealN") then it will catch too much. It's best to check every search result and make sure you want to change it first, and that's horribly time-consuming - though not necessarily what will happen.
Postby otters » 2009.12.27 (01:21)
No...no. http://forum.therealn.com/(wildcard) will match only URLs, just like http://forum.easterviking.com/(wildcard). It's a matter of simple regex.
Postby bufar » 2009.12.28 (00:37)
SlappyMcGee wrote:Have you tried either of the suggestions I've given in that thread?
Can you repost them here?
Postby EdoI » 2010.01.06 (21:35)
Haha, I've just noticed that forums.droni.es works, too!
Postby bufar » 2010.01.11 (09:18)
EdoI wrote:Haha, I've just noticed that forums.droni.es works, too!
That would explain why I couldn't stay signed in. I was using forums.droni.es, not forum.droni.es.
