I've tried to add a few images to my sig, but each time it says: It was not possible to determine the dimensions of the image.
Can you tell me how to fix this?
Sig Troubles
Can you tell us how exactly you tried to add the image? (what format did you use, etc.)
Step 1: I right click on the image and click properties.
Step 2: Highlight the URL, right click Copy
Step 3: Use then paste URL in between.
Step 1: You can just right click and select "copy image address" or something to that effect, but what you did should work anyway.Slayr wrote:Step 1: I right click on the image and click properties.
Step 3: Hm, what? Say your image is http://www.domain.com/image.jpg , you want to put
[img]http://www.domain.com/image.jpg[/img]
No such image at the location. It redirects to domain.com.Spawn of Yanni wrote:Step 3: Hm, what? Say your image is http://www.domain.com/image.jpg , you want to putin your sig. Not .Code: Select all
i tried to add another image and the same thing happened.
You're saying when you paste this exact code
into your sig, it doesn't work?
[img]http://i857.photobucket.com/albums/ab134/north_ocean/condemned2.jpg[/img]
yes
- Phei Phei Pho Phum
This is a real longshot, but are you over the character limit for signatures? You do have quite a few things in there already.
Edit: Eh, just eyeballing it, there's no way that's over 9999 characters. Back to the drawing board.
I'm pretty sure four signatures, thirteen little image bars, and an assorted shitload of shit is enough for one signature anyways.
- Sonnet
- NUMA Profile: http://nmaps.net/user/Kaylab
I under stand how to add a sig to your comment, im just not sure where you got/made your sigs from
You request people to make them for you. I suggest you browse through here.Kaylab wrote:I under stand how to add a sig to your comment, im just not sure where you got/made your sigs from
