My mappack broke :(
Moderator: zoasBE
Postby Sunset » 2009.12.12 (15:27)
Yeah, my entire 20 maps have been broken. all by the &userdata= code. I spent 2 days working on the mappack and now it's gone :c Please help. How do I make it possible to play on userlevels?
Postby blackson » 2009.12.12 (15:55)
You're gonna have to be a little bit more specific as to what went wrong before anybody can help.
Postby Sunset » 2009.12.12 (16:12)
After I put in &userdata=, I saved it. the next day (today) it was all corrupt! it was all ||||||0||||||||| and german letters and stuff. :c
Postby Izzy » 2009.12.12 (17:19)
I think we *just* ran out of duct tape.
Postby Sunset » 2009.12.12 (18:23)
onoZ! NOT THE DUCK TAPE!
Postby Tunco » 2009.12.12 (18:27)
Izzy wrote:I think we *just* ran out of duct tape. toilet paper.
Fix'd.
Postby Sunset » 2009.12.12 (18:34)
Let's be serious now. How do I fix this, yar?
Postby Pheidippides » 2009.12.12 (19:34)
SeventhSpirit wrote:Let's be serious now. How do I fix this, yar?
Oh, didn't realize you'd explained the problem. Ok. It sounds like it's not the fault of the &userdata= tag at all, and that your computer just messed up. That's what I'm led to believe, anyway. Is what you said all that happened? Like, you literally added the tag, saved, and it messed up?
Postby Sunset » 2009.12.12 (19:41)
That is what happened, Phei.
Postby aids » 2009.12.12 (19:48)
You could post the data to see if we can manually fix it.
Postby Sunset » 2009.12.12 (20:17)
well I kinda deleted the file :/ Was too lazy to actually fix the entire thing. But nvm problems gone now. Can someone please lock this?
Postby Rhekatou » 2009.12.13 (02:17)
SeventhSpirit wrote:well I kinda deleted the file :/ Was too lazy to actually fix the entire thing. But nvm problems gone now. Can someone please lock this?
After all that, you gave up?
Get that file out of the recycle bin right now!
Postby Sunset » 2009.12.13 (03:19)
if you insist :/
Postby Sunset » 2009.12.13 (03:21)
As you can see, it's completely broken. I can't get it to open up the files either :c
And it's not the first time either. This happened before. The files were corrupt, and I deleted them. Then a few months afterwards when I try to find the map again, it just pops up in some wierd place I never even knew was in my computer. Wierd...
Postby Sunset » 2009.12.13 (14:02)
hullo?
Donator
Donator
NUMA Profile: http://nmaps.net/user/DW40
Postby DW40 » 2009.12.13 (14:44)
What did you save the file as?
Postby Sunset » 2009.12.13 (14:51)
a normal notepad file, why?
Postby blackson » 2009.12.13 (17:16)
SeventhSpirit wrote:if you insist :/
I have no idea how you did that O.o
In the future, please refrain from posting multiple times in a row; instead, edit your post.
Postby Sunset » 2009.12.13 (17:44)
sorry blackson :/
But can you fix it?
Postby Rhekatou » 2009.12.16 (03:37)
SeventhSpirit wrote:sorry blackson :/
But can you fix it?
Nope. I don't know what you did, but that's beyond hope. Too bad you don't use shadow?serve?.
You can retrieve previous versions with it. =P
