A Day at the Office
Postby Tanner » 2009.11.28 (22:51)
Haha. That fire demon is so pissed.
Postby Leaff » 2009.11.28 (22:57)
Spontaneously become a ninja.
Postby LittleViking » 2009.11.28 (22:58)
The guy at the door doesn't even look that angry. Just a little confused. Explain what you're doing so he doesn't feel out of the loop.
Postby Skyling » 2009.11.28 (22:59)
Quick, tell the fire demon to immolate the guy!
Postby Torex » 2009.11.28 (23:17)
Jump off because the fire demon is burning your genitals.
Postby Donfuy » 2009.11.28 (23:30)
Uh... put a big smile, grab the keys smoothly, climb down of the demon, pick the kit-kat and bribe the supposedly bad guy with it.
edit: oh, and this is plausible because that bad guy doesn't seem to have a gun, and you're the one with the keys.
Postby Spawn of Yanni » 2009.11.29 (00:13)
Skyling wrote:Quick, tell the fire demon to immolate the guy!
What should I do?
Postby Donfuy » 2009.11.29 (00:21)
Oh, get out of there and check what's outside. Don't forget your two partners. And the kit-kat.
Postby Torex » 2009.11.29 (01:10)
Write "YANNI WUZ HERE" on the wall with the pencil, and then erase it when you see a guard coming by.
Postby Spawn of Yanni » 2009.11.29 (01:16)
Donfuy wrote:Oh, get out of there and check what's outside. Don't forget your two partners. And the kit-kat.
What should I do?
20% Femme Fatale!
20% Femme Fatale!
NUMA Profile: http://nmaps.net/user/Clifty
Postby Kwiftee » 2009.11.29 (01:20)
Check to see if there's a label above the door of the room you're in.
kind of really inactive nowadays ;_;
N Fight - I SWEAR THAT I'LL DO NUMBER 5 SOME DAY
<Skyline> And in conclusion, Kwiftee is so outrageously hot that he puts the general public in risk of burning.
<3 Skyline
NUMA Profile: http://nmaps.net/user/sept
Postby sept » 2009.11.29 (01:20)
Attempt to escape and force any guards you encounter to engage you in double decker fights.
Postby Spawn of Yanni » 2009.11.29 (01:27)
Kwiftee wrote:Check to see if there's a label above the door of the room you're in.
What should I do?
Postby Torex » 2009.11.29 (01:45)
Kill the fire demon before he blows shit up.
Postby noops » 2009.11.29 (01:57)
Open Osama's Suite and tell him about the explosive stash. Then tell Obama, who will try to deter Osama from terrorizing things. While they are distracted, enter the third door.
Postby Spawn of Yanni » 2009.11.29 (02:42)
Torex wrote:Kill the fire demon before he blows shit up.
What should I do?
Postby Torex » 2009.11.29 (02:45)
Softly bite the skin of the explosives' scrotum.
Postby Spawn of Yanni » 2009.11.29 (03:52)
Torex wrote:Softly bite the skin of the explosives' scrotum.
What should I do?
Postby Pikman » 2009.11.29 (04:08)
Look for an opening. If you find one, tell your red friend to burn it open.
Postby Spawn of Yanni » 2009.11.29 (04:36)
Pikman wrote:Look for an opening. If you find one, tell your red friend to burn it open.
What should I do?
Postby Skyling » 2009.11.29 (04:56)
There's no time for air to the surface! Just go back and run into one of those suites (or the sweet). I'm sure one of them has to have a window you can escape from.
Postby Spawn of Yanni » 2009.11.29 (05:21)
Skyling wrote:There's no time for air to the surface! Just go back and run into one of those suites (or the sweet). I'm sure one of them has to have a window you can escape from.
What should I do?
Postby unoriginal name » 2009.11.29 (05:23)
Call Jack Bauer.
Postby sept » 2009.11.29 (05:28)
Stealth kill the fire demon with your pencil, and then attempt to survive the blast by using his body as a shield.
Postby Spawn of Yanni » 2009.11.29 (06:06)
sept wrote:Stealth kill the fire demon with your pencil, and then attempt to survive the blast by using his body as a shield.
"NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO"
WHAT SHOULD I DO.
