I'm using a 64 bit system, don't know if the same will happen on 32 (or other 64s for that matter).
The basic issue is that N lags. It's not the Vista issue whereby frames freeze from time to time.
The game in general plays as though it's missing out every other frame - even at a constant 8ms/f.
Every 25 or so frames, the frame time will skip from 8 to ~27ms/f for just one or two frames, then return.
Any idea of a solution to this?
It's not at a point where N is unplayable, however I couldn't imagine myself getting many decent demos as it currently is.
N on Windows 7
- MBTI Type: ESFP
Hi.
Switch to Ubuntu.amomentlikethis wrote:Any idea of a solution to this?
Be a dick.
Edit: Ohhh, wait, that isn't a solution to your problem. Have your tried the sound-enhancement fix that usually works for Vista?
- MBTI Type: ESFP
I have, and it didn't fix it. It's not the same issue Vista has.Spawn of Yanni wrote:Ohhh, wait, that isn't a solution to your problem. Have your tried the sound-enhancement fix that usually works for Vista?
Hi.
Weird. I guess we'll have to wait a bit and see if this is a common problem.
I'ma put N on one of my Win7 machines today, and I'll see if I can't get a solution for it.
It's somewhat late, but if you haven't already resolved the issue, turn off Windows Aero and the other visual elements that make 7 look so pretty. It should run perfectly fine after that.
- MBTI Type: ESFP
Ah, I fixed it by changing the compatibility mode to Windows XP.
Hi.
- Tetris
- NUMA Profile: http://nmaps.net/user/Sahathai
I have another question!
I don't know where is my sol file?
- MBTI Type: ESFP
Why do you need to know where it is?Sahathai wrote:I have another question!
http://metanet.2.forumer.com/index.php?showtopic=6036
Hi.
- Tetris
I will continue playing on other computer...
