NReality Bounceblock Mod
NUMA Profile: http://nmaps.net/user/clarie150
Postby clarie150 » 2008.11.16 (00:05)
I was playing out a mod (4,sleepThreshold,0;) on NReality, when THIS happened.
Can anyone explain it? If it turns out to be obvious, please don't spit the dummy.
BounceBlock.txt
(1.53 KiB) Downloaded 305 times
Postby sheganican » 2008.11.16 (00:36)
spit the dumby is a cool phrase.
i cant explain it, but its cool. i have yet to experiment in the field of code editing.
Postby clarie150 » 2008.11.16 (00:50)
Actually, What I Meant Was:
The Bounce-block directly under the launch-pad freezes and pretends it has no mass, allowing the Ninja to move through freely. Weird.
@ Eganic: I can come up with a lot more 'cool phrases'. Gimme time.
Postby Yoshimo » 2008.11.16 (17:34)
Try this on for size!
To cool for most human eyes. Click if you dare!!!
Click if you clicked above
The bounceblocks in this level react really cool. They 'diffuse'.
Postby Rikaninja » 2008.11.17 (07:27)
Check this Bounce Block mod out. That was awesome by the way. Srange.
||||121,speed,1.8;4,stiff,-0.2;4,mass,0.999999999999;4,sleepThreshold,10000
And this is almost as good:
||||4,mass,10
And this is a moving Bounce Block!
1^780,384^^^L,6,0,0.67
HAHA
Postby clarie150 » 2008.11.21 (08:24)
BionicCryonic wrote:Try this on for size!
Yeah, I've seen it. It's AWESOME! Mind if I use it in another DDA?
Postby Yoshimo » 2008.11.21 (21:15)
Go ahead, just make it tasteful! (Not so much enemies that you can't focus on the mod)
