ModMaster v1.4 *** Dronie Award :: Program Of The Year ***
Postby NPLUS » 2010.08.25 (21:50)
BUG: When changing the icon on tile drone, it use object number 0, instead of 122
NUMA Profile: http://nmaps.net/user/kyozo_43
Postby kyozo_43 » 2010.11.30 (05:51)
Erm ... one question -
Where is the file "NReality Helper 2" ?
In the .zip file all that I can see are -
modmaster 1.4.exe
ReadMe.txt
Hope you can help!
Postby 大見解 » 2010.11.30 (11:34)
modmaster 1.4.exe is the one you want to run.
Postby kyozo_43 » 2010.11.30 (21:05)
大見解 wrote:modmaster 1.4.exe is the one you want to run.
hmm ... I tried it just then and it worked ... before there was some odd error message ... xD oh well ... thanks, I guess >_<
Richard Richards
NUMA Profile: http://nmaps.net/user/epic4ever
Postby Equilibrium » 2011.02.21 (14:22)
Okay i have a question from where to where do i copy and paste the code that the ModMaster v1.4 gives me??
Postby remm » 2011.02.21 (23:11)
The code that modmaster gives you is at the bottom of the modmaster window in that box.
Depending on the type of code that it gives you, you put it in one of two places.
If it is an object, then you can just copy it onto the end of the map code in the Nreality editor. You will have to re-paste it back in after each edit, however, because Nreality won't keep it there. It is only an addon to the old N editor, which does not support the Nreality additions.
If it is not an object, (so it's a player mod, etc) it will begin with |||| and use words, like startaccel or whatever, this must be at the end of the code, and you will have to re-paste it there after each edit you will make.
This is all assuming you have made maps before, and know how to work the N editor.
peking^
Richard Richards
Postby Equilibrium » 2011.02.24 (14:04)
I have found a glitch with the rotating laser, in stead of being placed on the map its being placed in a corner outside the map!!! how can i fix this??
Richard Richards
Postby Equilibrium » 2011.04.17 (21:13)
I am trying to put an image on to a map but i do not get it.. What is the url that i need to put in the Foreground / Backround???
Postby atomizer » 2011.04.17 (22:07)
You reeeally should read this. Also, there is The NReality Mod Help Thread, which is worth reading too.
The Loneliest Number
Postby Cheyo » 2011.06.04 (15:49)
Sorry for bumping, but I have a question--how do you apply the changes you've made? What do you need the code for?
Postby Sunset » 2011.06.05 (00:03)
Cheyo wrote:Sorry for bumping, but I have a question--how do you apply the changes you've made? What do you need the code for?
You're gonna have to go more in-depth, sir. If you want to apply the NReality mods, you put a | at the map data, and after that you put the code that ModMaster put for whatever mod you wanted.
Users browsing this forum: Bing [Bot] and 5 guests
