Deleting a corrupt file
So far, I have tried to delete it normally, by browsing to the file; I've tried deleting it in Safe Mode; I've run Chkdsk three times at varying levels of intensity with no luck; used a program called Unlocker to no avail; and tried to delete it using cmd, but got the same error message - "The file is corrupt blah blah".
I cannot move it, rename it, or gently caress it. I'm beginning to think that the only option left - aside from just letting the bubble pop up every freaking time - is to reinstall Opera and lose all my settings (would I?) but I'm hoping that you guys have any ideas.
Also, Vista.
What I'm guessing is that the file metadata got messed up in such a way that the size is incorrect, which would mean that deleting the file might overwrite other files. You could try to change the filesize in Properties, but I don't know how to find the correct size.
Also, could we see the exact error given by Windows (not Opera) when you try deleting it?
I've already tried using Eraser, but all that does is overwrite a file several times so it's unreadable (basically, it corrupts a normal file) and you can't overwrite a corrupt file.
The error in question is error 0x80070570, giving the message "The file or directory is corrupt and unreadable".
2) defragment
3) chkdsk
4) use a recovery tool like R-Studio to 'restore' the file (all this will do is write size parameters to the file table), and you should then be able to delete it normally. This could very well result in deleting other things, though.
I think that Unlocker's window opens as soon as the 'Can't delete...' message jumps out, but I found it easiest to right-click the file, press Unlocker and choose option 'Delete'.
Edit: Reinstalling Opera will leave you your bookmarks, widgets etc. But that makes me think that reinstalling would also leave the same problems. Did you try Unlocker, and did it work for you?
Boot into Safe Mode and try to delete it again.Spawn of Yanni wrote:The filesize claimed by Explorer is 0 bytes, scythe, but I don't know how to use Properties to change filesizes.
...then defrag your hard drive and/or sfc scan, because this is a pretty frickin' medieval approach.
I haven't used cygwin much, but if dev/null/ does what I think it does (overwrites everything between 2 locations with NULL ignoring all types of termination characters) that's probably the most likely thing to work. If Tsukatu's suggestion doesn't work, I don't know what will. Possibly throwing the hard disk into a volcano?
Mm, indeed. The file would, in fact, be gone.Exüberance wrote:Possibly throwing the hard disk into a volcano?
