Your Flash player Might be running with an abnormel speed!
Postby Guest » 2008.11.04 (18:35)
LOL!
I was making a Race map in N-reality when all of the sudden a red text flashed (text: Your Flash player Might be running with an abnormel speed!)
What the hell!
what happend, I just lost my racemap!!! it was pefect! OMG! why!
lawl ofcourse I was too fast in my race map llol.
how can I fix this or remove this?
Postby b3njamin » 2008.11.04 (18:36)
Btw it's me b3njamin
Postby Kablizzy » 2008.11.04 (20:43)
Oh, no! Well, I don't know what Nreality has done with the Flash player, so I really can't say what's going on. Hope things work out! =D
Postby George » 2008.11.04 (23:40)
I don't think much can be done about it. It's just one of those random bugs that N Reality gets. I've had the unfortunate mishap of running into that as well, so all you can do is regularly save your data.
Postby Riobe » 2008.11.05 (05:55)
George wrote:I don't think much can be done about it. It's just one of those random bugs that N Reality gets. I've had the unfortunate mishap of running into that as well, so all you can do is regularly save your data.
This fact alone has made me start using N 1.4 more often nowadays. There are solutions I can think of though:
1) Save your data regularly. Sometimes, the player just crashes randomly, so this is a good solution.
2) This may not apply to everybody, but I notice that the longer the player is open, the more likely it is to crash all of a sudden. If NReality has been open for hours, and it hasn't crashed yet, close that one, and re-open it, then start your level again.
3) Start using Nv1.4c much more often when making non-Nreality levels if you'd like to completely avoid this problem. The normal N doesn't crash due to the flash player, and if it does crash, it's not the flash player that caused it.
4) This may also not apply to everybody, but keep as much things closed as you can. With my computer, the more things I have open, the more NReality laggs, and the rate at which it crashes increases.
Well, thats my four cents.
Postby Evil_Sire » 2008.11.05 (16:12)
If Nreality starts lagging, hit the boss key and wait for a while. It should deplete the lag and make it run longer.
When Nreality does start lagging though, it means you are likely heading for that "abnormal speed". It's only ever happened to me once, and I wasn't annoyed, because I had a load of save files each with a different step.
Normally, it helps if you do it in steps. Make a part, save it, then restart Nreality.
If the problem persists, PM unreality or start using Nv1.4.
Postby mathy » 2011.09.04 (12:33)
That happens whenever I open 2 Nrealities at once.
Postby EddyMataGallos » 2011.09.04 (13:00)
Thats not a bug guys, thats an antispeedhack method implemented by UnReality, if youre trying to slow down the game (eg Cheat Engine) youll see that message, but also youll see it when its lagging.
