Yo. :P
So yeah, as the title says, I can't submit my map for some reason. When I try to submit it, I get the error "No objectid for object". I submitted a map just earlier, so why doesn't it work now? o.o Yes, there are objects in the map.
Thanks. :P
Edit: Well yeah, it apparently fixed itself. o.o How come?
Can't submit my map.
- Member
- NUMA Profile: http://nmaps.net/user/el_devo
I've had this problem before, the error seems to come from not having the '#' at then end of your map data, or not starting it with a '$' Hope that helps.
- Semimember
As said, it already fixed itself. I think it's because I accidentally dropped a character somewhere. xD
You cannot post a map without any objects in it. Even tilesets need to have some object hidden in the tiles for the website to accept it.
- Semimember
Well I know. o.o It was a normal map with objects in it that worked in ned too. Maybe it was just a glitch on the website, since it fixed itself. :P
