What should I do next?
First, put the data in map tags. Second, add speed to the start. In a start like that, you need some intitial speed.
Hmm, I'll try lowering him into the ground a bit.
mapping since '06
-+- njitsu -+-
-+- njitsu -+-
- NUMA Profile: http://nmaps.net/user/Guiseppi
The beginning is too difficult. Way too difficult. I think adding a big jump off the platform at the right would be cool, and then having some more stuff at the bottom. I also don't think it flows well with the launch pad at the top, but maybe I was just doing it wrong.
Are you kidding? It's easy as hell. Just chimney. I can do it every time. Here's a demo (for the newer version of the map I posted below) It's even possible to do it and only get one of the two gold pieces covering that mine, but that's really hard :pglümp wrote:The beginning is too difficult. Way too difficult. I think adding a big jump off the platform at the right would be cool, and then having some more stuff at the bottom. I also don't think it flows well with the launch pad at the top, but maybe I was just doing it wrong.
I changed the third segment to something actually fitting.
mapping since '06
-+- njitsu -+-
-+- njitsu -+-
