Passing Through Locked Doors
- NUMA Profile: http://nmaps.net/user/mohit_ghune
Once you perfect it you can even be like the players who are able to beat this. Gaining enough speed in such a little space is very hard, people usually use two keys for this trick, when done consecutively and successfully it produces a lot of momentum for your little guy.
Also, if you want to partake in highscoring discussion or just want to talk, feel free to visit the IRC server; irc.mountai.net.
For the backwards bounceblock wall jump, you have to hit jump when you're at the bottom corner of a bounceblock and going in the right direction. Have a look at 27-3 highscore or 61-3 speedrun. There's not much to be said about this other than try it and see what happens.
There's also this, which is corner-kicking off of bounceblocks: http://pastebin.com/bqhBgS5F The only difference is falling and kicking off one of the upper corners.
If you want more information, I'd go here: http://forum.droni.es/viewtopic.php?f=21&t=6065 Scroll down to where it says: "Tricks based on Glitches" and it will give you more in-depth explanations of these two tricks and many more. With that being said, I'd highly encourage you to go on IRC and use the #n-highscores channel as 999_Springs said.
Sig by Aidiera.
Just thought this was a hilarious response, and even the title of the thread would seem to lend itself perfectly to a spambot that looks for keywords of locks and doors. After all, who else but a burglar would want to pass through a locked door?RichardCain wrote:Some burglars are really expert when it comes on breaking ordinary locks. It is really important to choose locks that cannot be easily break by these persons.
*spambot link*
- Radio Douchebag
Have you ever tried that? It's harder than normal single-button jumping with little benefit. I've been playing N compulsively for years now. All it takes is dextrous and agile fingers, and a responsive keyboard.Rhekatou wrote:For the chimneying, you can do "fluttering" (I forget what it was called <_<) where you use 2 fingers on opposite sides of the shift key and just alternate pressing with each one.
Trilling.▲▪►▪▼◄▲ wrote:Have you ever tried that? It's harder than normal single-button jumping with little benefit.Rhekatou wrote:For the chimneying, you can do "fluttering" (I forget what it was called <_<) where you use 2 fingers on opposite sides of the shift key and just alternate pressing with each one.
This is exactly what I do, as I mentioned in an earlier post. I just find it slightly faster and less tiring than using one finger, and I'm hopeless at double shifting. It honestly depends who you are, I mean different people will adapt better to different styles; I'm a pianist so I'll naturally favour alternately using two fingers on the same hand. A drummer, for instance, would prefer something else.
