I would like to put N in a USB...
NUMA Profile: http://nmaps.net/user/Ferox%20
Postby Ferox » 2010.09.23 (11:45)
Okay, so I want to put N and NReality in a USB drive. Does anyone(T3chno) know how I can do this? My problems are with the .sol file.
Postby Pheidippides » 2010.09.23 (16:13)
If you're running Windows...
Start --> Search --> *.sol (make sure you're looking in hidden files and folders) --> find n_v14b_userdata.sol --> Open Containing Folder --> copy the file to your USB drive.
Then, when using N on a different computer, start N and allow Macromedia Flash Player to store data. This creates a fresh .sol file. Then...
Start --> Search --> *.sol (make sure you're looking in hidden files and folders) --> find n_v14b_userdata.sol --> Open Containing Folder --> replace the fresh .sol file with the one from your USB drive. Then you'll have all of your data on the new computer. Also, don't forget to copy the .sol file back onto your USB when you're done playing so that the data on the USB drive stays up to date.
