N Lag?
- Pure
Whenever I play N on my Windows 7 computer, It takes up at least 50% of the CPU, usually higher, at values around 90%. I turn off stuff like Firefox but lag spikes occur. I found that svchost.exe can cause extreme lag, but that only occasionally happens. Is there a way to rid of the high CPU usage?
Direct your complaints to Adobe. Flash blows goats at efficient CPU usage.brianlyao wrote:Whenever I play N on my Windows 7 computer, It takes up at least 50% of the CPU, usually higher, at values around 90%. I turn off stuff like Firefox but lag spikes occur. I found that svchost.exe can cause extreme lag, but that only occasionally happens. Is there a way to rid of the high CPU usage?
Consider putting the quality down too. Antialiasing can kick old computers/netbooks/small notebooks in the face, if you're running on one.
Turn off Windows Aero to Windows Basic.brianlyao wrote:Whenever I play N on my Windows 7 computer, It takes up at least 50% of the CPU, usually higher, at values around 90%. I turn off stuff like Firefox but lag spikes occur. I found that svchost.exe can cause extreme lag, but that only occasionally happens. Is there a way to rid of the high CPU usage?
- Pure
I have already turned Windows Aero off to Windows 7 Basic. I have tried to turn the quality down, but strangely it has no effect on the CPU. I guess I'll have to put up with it. Thanks for the help anyways, guys. :)
This may have something to do with older flashplayers not working properly with Windows 7.. performance should be greatly improved when we recompile the ported version for player10.
