Welcome one and all, to the revisited MICC!, here's what you need to know
Q: Revisited?
A: Now, this is what the contest should have been like ages ago. You're gonna have much more fun.
Q: So they both had different judging methods, so will this one be the same?
A: No, actually this one will use public votes in a similar style to SotW. So this should make things interesting.
Q: Will there be any prizes for winning?
A: None this time unfortunately.
Q: How long will this run for?
A: 10 weeks, as long as southpaw doesn't hijack me back :P
Q: Rules?
A: Yes.
- All work must be new and fresh, not rotten apples please.
- You may submit work to deviantART/Flickr etc.
- You may only submit once, not twice, once.
- Keep your images in .PNG format, you should know better if you're participating...
- You need to PM me your image.
Ok guys, here's your first challenge, you have to create a signature. Doesn't sound too hard does it? But there's a catch, you can't make it more than 550 pixels in width and 200 pixels in height (Obviously this is the max canvas size, if you make the sig 600x250 but the size of the inside image is 550x200 it will still not be accepted). And the final catch is this, you have to use this image in your signature. Good luck.
Take a stock photograph, and add effects to make it look more appealing. Use your imagination!
What you have to do is take a stunning photograph of something involving nature, be it an animal or plant or fish as long as it isn't rude. You may use camera filters for this to improve your photograph, but you cannot modify it in an image editing program in any way. Yes I know this strays from the original name but it's to do with imaging. Now get snapping!
